Automate exporting data
Is there any way to automate exporting data from a table visual in power bi.
I want it from the table visual and not power query
Hello @Anu,
Well I’m afraid to say but I guess this is still not possible in Power BI by way of automation to export the data from a particular table visual. There’s a idea on this which is under the status “Need Votes”. You can also provide a vote on that idea.
I’m also providing a link below where similar sort of query was asked onto the Power BI Community Forum as well but no solution is provided against it till date.
Hoping you find this useful. :slightly_smiling_face:
Thanks and Warm Regards,
Harsh
https://ideas.powerbi.com/ideas/
Hi @Anu, we’ve noticed that no response has been received from you since the 13th of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
