Anyone knows what is the language that M Language for power query compiled on?
Or in other words, is it for example based or compiled on C Language or alike?
M stands for Mashup. The M language is a functional, case-sensitive language similar to F#, which is used inside the Power Query Editor.
Thanks for your reply.
But I which language it is based on or compiled.
For example, PHP is based on C, so For M language, which one it is compiled or based on?
@MGadAllah
I understand what you are asking but i don’t see anything other than what @Melissa has stated in her reply. ( I spent about half hour browsing the internet)
It is also known a data mashup.
My suggestion would be is for you to contact Microsoft to see if they have anymore information on it.
thanks
Keith
Thanks a lot for your reply.
I will follow your advice.
But may I ask, would you suggest the power bi community or there is a better medium or channel?
Thanks a lot.
yeh you can ask them or search it yourself too.
I couldn’t find anything on it on youtube or on the internet about it. all i could find what the language was code and functions of the m that is used in power bi and excel in power query.
thanks
@Melissa @Keith Thanks a lot for your valuable time replying to my thread and helping me.
don’t forget to marked solved
thanks
Hello @MGadAllah
Thank you
