I was fortunate enough to attend yesterdays session where Brian took us through using Power Query to allocate a simple monthly budget. My question is a bout how the steps would differ if you have multiple brands or products to allocate using the same method.
I have attached my file using a slightly different GroupBy approach which appears to work but is showing an error message. Is this the correct way to do the allocation?
I will attach my file so you can see what I am attempting to do, using just two brands.
Glad you found the session helpful. I’m just getting ready for a houseful ofThanksgiving guests to arrive, but will put together a solution on this late tonight or tomorrow morning. Same basic principles apply, just with a couple of twists.
Yes I will attach the three files. They are very basic. If it is easier I have the file where you aided a previous question on monthly budget allocation(MyFakeRetailReport). I will attach in case that is a better one to use(more brands with forecast). Either way thank you very much for taking a look at this.
The pbix prior solution is on this page "Qty by Day & Month and your measure was “2020 Forecast Qty Allocation”.
Outstanding and thank you. This is a great alternative you came up with. I imagine this will prove useful in many instances. Again thank you for your time and expertise!
