Hi!
I recently bought a membership which I had thought included Analyst Hub. However, for example, when clicking on Community I get a Locked Feature page.
Am I mistaken?
Cheers
Tina
Hi!
Am I mistaken?
Cheers
Tina
Hi @TinaHelg,
Welcome to the forum!
The @EnterpriseDNA team will have to look into that for you.
Let’s send them a signal…
Thanks Mellissa!
Thanks for sending the bat signal, @Melissa!
Hi @TinaHelg, you should receive an email from our Analyst Hub Team regarding your login access to the Analyst Hub. Can you check your inbox? If not, try searching in your junk or spam folder. If the email cannot be found, please send a message to analysthub@enterprisedna.co
