Dear Habib and other members of eDNA,
I am currently going through course: " Basics of the ChatGPT API". Everything was going well until I reached the step “Azure Function Testing and Deployment”, where created Function is deployed into Azure.
An error occurs during deployment. When I look into Output, the last lines describing a problem read as:
“4:02:42 PM learningopenai: Malformed SCM_RUN_FROM_PACKAGE when uploading built content.
4:02:42 PM learningopenai: Generating summary of Oryx build
4:02:42 PM learningopenai: Deployment Log file does not exist in /tmp/oryx-build.log
4:02:42 PM learningopenai: The logfile at /tmp/oryx-build.log is empty. Unable to fetch the summary of build
4:02:42 PM learningopenai: Deployment Failed. deployer = ms-azuretools-vscode deploymentPath = Functions App ZipDeploy. Extract zip. Remote build.
4:02:54 PM learningopenai: Deployment failed.”
I tried to use ChatGPT to ask for an advice, tried to create a new setting in Azure named “SCM_RUN_FROM_PACKAGE”, but it ended up telling that such setting cannot be saved. I also tried to go through some threads on stackoverflow, but described problem did not appear to be similar to mine. I am not proficient in programming and didn’t know how to implement their solution into my issue.
I am wondering if someone else encountered similar issue and found a walkaround.
Please, let me know if my question is not elaborated enough and you need any further details.
Thank you.
