Allocating a total value in column based on proportional values in another column
I would like to allocated the 2,000 value in Column B, based on Sales Mix values in Column A, see below. I hope this is enough information, I am fairly new to the Forum.
@Floyd,
Welcome to the forum!
SUMX is a great tool for this type of calculation. Here are a couple of excellent videos explaining it and other similar iterating functions:
https://forum.enterprisedna.co/t/sumx-averagex-minx-max/3278
https://forum.enterprisedna.co/t/iterating-functions-deep-dive-sumx-averagex-minx-maxx/2993
If you still have questions after taking a look, just give a shout.
@Floyd,
Now that I’m back at my computer, I put together a solution file for you.
Here’s the key measure using SUMX:
 Target Sales Allocated =
SUMX(
    Sales,
    [Sales to Allocate Value] * [Sales Mix]
Definitely still check out the videos above - tons of great info there.
Hope this is helpful.
Thank you Brian. I am quite new-ish to Power BI, so am just working through the example that you kindly attached and busy applying the logic to the issue I am having. Will be in touch once I get it all (hopefully) working on my side.
Steve
@Floyd,
Good luck with your project. Just give a shout if you have any questions or run into any problems.
Hi Brian
I have managed to get some of the way there. I have successfully created 2 of the columns below, but I can’t create the last one. I see that you created a What-If Parameter field which you populated with 2,000. The number (2,000) I need to reallocate actually resides within the data in a row called ā€˜Other’, under ā€˜Hot Dogs’.
Is there a way I can reference where ā€˜Column A Actual Sales’ = ā€˜Other’ and then use that as opposed to the What-If Parameter field ?
@Floyd,
Absolutely. I’m assuming based on the screenshot you provided, you don’t want to add a slicer by Product to your report. That’s definitely one way to set some of the filter conditions needed, but the solution provided below is sans slicer.
Here are modifications I made to the original solution file provided (new solution file attached below):
  1. in the filter pane for the table visual, I filtered out the ā€œOtherā€ row:
  1. created the following measure to capture the total value of the Other row to be allocated:
     Target Sales to Allocate =
         [Total Actual Sales],
         Sales[Product] = "Other"
  2. now we have to change the measure to calculate the denominator of our sales mix % from ALL to ALLSELECTED, since we want to maintain the filter on Other, otherwise our denominator will include the additional $2,000:
     Total Actual Sales ALLSELECTED =
         ALLSELECTED( Sales[Product] )
  3. and finally, change our Target Allocation measure to incorporate the value we pulled in from the Other row in 2) above
     [Target Sales to Allocate] * [Sales Mix]
Here’s how it all looks put together - I added a card visual just to show the $2000 value to be allocated, but it’s not necessary and can be deleted.
If you haven’t already, I would highly recommend working your way through this course, particularly the sections that focus on evaluation, filter, and row context and the CALCULATE and FILTER functions.
I hope this is helpful.
Thank you Brian, you solved it for me :slight_smile:
