ALL EXCEPT doens't seem to work?
I have a question about AllExcept.
The model is 1 table named “X” that has Tree columns=
[Nr] - [Colour] - [Date]
I use a measure Quantity = Calculate(count(NR), AllExcept(X, X[Date]))
I use both [Colour] & [Date] in the Filter pane in the “filter on all pages”’
I thought that when “slicing” (filtering) on [colour] (via the filter pane) my measure Quantity would not change, because of the “allExcept” statement applying that only [Date] slicing will affect the measure?
→ in my model now measure quantities changes on both filtering [Date] and [Coulour]
couple of thoughts myself:
  • is it not working because of 1 table in stead of “lookuptables”? (like a date table etc)
  • is it not working because of using the filter pane to slice the report instead of a slicer on the page itself ?
Thanks a lot in advance
Kind regards,
Martin
Hello @Martin2140, good to see you again the forum :slight_smile:
I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
  • A mockup of the results you want to achieve.
  • Your current work-in-progress PBIX file
Hi @Martin2140, we’ve noticed that no response has been received from you since August 17. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model.
