Agriculture Models
Are there any examples of nice models/reports for Agriculture out there?
@cms418,
This question can be best answered by using your trusty friend: Google! Do a search for this and I’m sure there is content on YouTube and other sites!
Jarrett
Check out this report, it seems intersting. You can get the inspiration from it
Partner showcase | Microsoft Power BI
Hi @cms418, did the response provided by @HASSAN_BI and @JarrettM help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @ @cms418, we’ve noticed that no response has been received from you since the 12th of April. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @cms418, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
