In the diagram attached…i have a data model …which has two fact tables and few common dimension tables. Looking at the diagram can i say it has 2 snowflake schemas.
any advise will be appreciated.
regards
*** READ FIRST ***
Before you send your question.
Make sure that all details relevant to your question is complete:
Your current work-in-progress PBIX file - VERY IMPORTANT
A clear explanation of the problem you are experiencing
When it comes to Power BI, my advice is always to shoot for the star schema if at all possible. Here’s a slide I prepared for the Accelerator course week #2 on Data Modeling. Without knowing more about the specifics of your data, my inclination would be to de-normalize Dim1 and Dim2 down to a single dimension to make it star schema compliant.
Yes sir you are correct… i always create star schemas… but if some one asks what kind of schema is that? in that case can i call them it is having 2 snowflake schemas?
@praveer82
Great Question.
Simple answer is it is a Galaxy Schema.
In the examples below you can see the difference between the 3 schemas discussed.
Note:
The examples are laid out using the Collie Method.
This helps you to quickly and easily understand the filter propagation in Power BI.
Using the Collie Method, the filters will always propagate downhill.
Thanks sir…for reply, actually it does not seems a galaxy schema as galaxy schema consists of multiple star schemas… but in my case its forming snowflake…please suggest…can i say its combination of two snowflakes?
regards
Essentially, a Galaxy schema can be defined as a collection of star schemas interlinked and completely normalized, to avoid redundancy and inaccuracy of data. It can also be a meaningful association of a Snowflake schema with a Star schema, etc, where the fact tables of both schemas can be linked by common dimensions.
Your Dim1 table makes your Galaxy a combination of 2 snowflake schemas
