Still a newbie with Power BI. Been focusing on elevating my Dax skills and should have spent a little more time on Database Schema.
I know I am making this harder than it needs to be, and I am sure you experts know what to do in this case.
I am trying to create a promotional database.
The problem I am running into is that the promotions are the same except that they span multiple accounts.
Please see attached example of Data fields.
So, I will create the following tables:
Not sure how I should create a relationship between Promo and Sales table since there can be multiple products in the same promotion but for difference customers.
Hi @KBG, did the response provided by @mspanic help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @KBG, we’ve noticed that no response has been received from you since May 26th. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @KBG, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
