I reviewed the video. First of all, I think that there is a misunderstanding. Sam, didn’t use measures in the Regions lookup table, he actually used “Calculated Columns” instead. Both the “City Group” and “City Sales Rank” are calculated columns as their icons show. As he mentions through the video, this is another great technique for segmentation.
Second, you don’t need to revise the measures or calculated columns every time you refresh the data. All the measures and calculated columns in Power BI are dynamic.
Just a point of clarification here. Measures in Power BI are fully dynamic. Calculated columns are not dynamic within the scope of a reporting session. They update only upon refresh of the report.
I think this discussion was primarily focused on the need (or not) to continually update measures and calculated columns across reporting sessions, so @sedhosen’s point is correct in that regard, but I just wanted to prevent any misunderstanding by someone reading the thread.
– Brian
John – FYI, the response above was not mine – that was the Enterprise DNA team that supports the forum behind the scenes. While I work for Enterprise DNA, on the forum I will always use my @BrianJ account when responding.
Hi @JohnG , did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @EnterpriseDNA, this actually is @JohnG question. I just tried to solve the question, and @BrianJ kindly helped me by mentioning some important notes.
Hi @JohnG, we’ve noticed that no response has been received from you since the 14th of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @JohnG, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
