I want to know the best practice for the below asked question:
Should i create view on sql or use advance query editor to fire query on sql server.
which give me best performance or it will be same any approach will be good.
I mean should i use below option
or i create view and just use
Select * from [view];
@Anurag ALWAYS use a View. A View acts as a layer between your Physical table and the client tool. You can make all the changes in a view and then import it inside Power Query whereas if you directly query a Physical table then if tomorrow you want to add a new column then you will have to modify the physical table or do it in Power Query (which may not support native query)
A view with a Schema allows your DBA to know that there is a view that is using some tables in the model to fetch the data for a project, this prevents them from modifying/removing the tables before reaching out to you.
With a SQL query you will have to use Value.NativeQuery function explicitly.
I am agree with your point here but just one more question which is bothering me here does view give me better performances vs putting sql query in power bi.
Hi @Anurag. Your DBA should be able to answer this for your specific environment. As a general rule of thumb, I’d go for the view, as SQL Server will cache the execution plan for the view and reuse it, whereas a text query will need to have a new query plan created each time it’s executed.
