but here in the formula at around 7min30, I would like to have the cumulative sales to add the forward forecasted months in my case ( for example actuals until August which is period 8 and add the forecasted revenue of P9 until P12).
You need to calculate a point in time where you switch from Actuals to Forecast.
In the course you referred to that’s the Sales[OrderDate] since that is all I have to go on at this point - it’s going to be difficult to provide better support without a sample file that matches your current situation.
for the Sales[OrderDate], I don’t think there will be an issue, I just need a way to insert my measure [GR Actuals] where you have put ALL(Sales)
To explain better, I don’t have a sales column in my fact table, I have only " amount" where you find all the income statements accounts, so I created a measure that filter the Revenue account.
Hi @Rachid, did the response provided by @Melissa help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @Rachid, did the response provided by the contributors help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
