I am trying to add custom font family in my power bi but not able to do that so .
I want to add the bold variant of the text family in power bi but on import it show the font in normal weight .
Adding the json which i used to add to add bold font
{“name”:“Helvetica Neue Bold”,
Hi @Anurag, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster.
Did you see this note in the article and apply the workaround as suggested?
One more important thing to keep in mind : if you manually change the font of the visual once you open your .pbix file, BEFORE importing the theme, and then import the theme, changes will not be applied! I don’t know if it is a bug or what, but let me show you what’s the issue:
The theme generator mentioned in the article would give you a custom set of JSON which you could then modify to match what you’re wanting to do. It looks like it covers the areas you want to customise.
