When trying to add a “Custom Column” using the following code:
= Table.AddColumn(#“Changed Type”, “Status”, each IF([Registered Credits] >= 12, “Full Time”, “Part Time”))
Power BI returns the error message:
Expression.Error: The name ‘IF’ wasn’t recognized. Make sure it’s spelled correctly.
Thank you in advance for any help with this issue.
Eduardo From Ann Arbor, Michigan.
This should work for you, you were missing the then & the else. IF statements work the same way as they do in Excel but they have different syntax.
Table.AddColumn(#“Changed Type”, “Return”, each if [Registered Credits] >= 12 then “Full Time” else “Part Time”)
David
Great support @DavieJoe !
@lebtechus please know that Power Query is case sensitive, therefore keywords like: if, then and else need to be written in lowercase as illustrated in the first response by @DavieJoe
Ah, yes, great point about lowercase. I FORGOT that BIT
DavieJoe: Thank you for the reply. I will keep your advise in mind when working with Power BI. I am an old SQL programmer that loves to write statements in upper case. My query now works fine.
Cool, don’t worry, I come from a heavy Excel background and I have to regularly remind myself that IF statements work in the same way but with slightly different syntax.
