For the first time I’m trying to add a sharepoint connection to my gateway connection for power bi online. My gateway connection screen looks like this:
I found a online thread that says online data sources cannot mix with on premise data sources but the option is the use the gateway, when I’m setting up the sharepoint link so, not sure this is exactly the issue?
We’ve been using a mixture of the 2 since we started with PowerBi just under 2 years ago. However the last few days we’ve noticed the same issues you’re facing for a new report we’ve done, so it may be something has gone wrong with it on Microsoft’s side.
We’ve also done it the same way as you’ve described and never had any problems.
Due to the length by which this post has been active, a response on this post has been tagged as “Solution”.
Thanks to @jamie.bryan for contributing on this post.
For further questions related to this post, please make a new thread. Please feel free to reopen this thread if anyone would like to answer the pending inquiry above.
