Adding a Legend to Chart: Wrong totals by each Legend item
Refer to images below and attached simplified data model (and source table) for more details. Intent is to show reverse cumulative counts for all future years – and embed a Legend (Companies), where each bar shows the correct totals that comprise each years count of unexpired licenses:
In Chart #1, no Legend has been added. Correctly shows Reverse cumulative totals of unexpired Licenses by year:
In Chart #2, a Legend has been added – Company. But it scrambles the above counts of Licenses, and does not show the relative counts by Company:
DAX Problem - Add Legend to cluster Chart (counts).pbix (64.4 KB)
Mockup source file.xlsx (17.3 KB)
Hi @mdalton2100 ,
It’s context problem.
You need to create star shema - to add separate dimensions that you want to use - company and year
After that you need to switch your measure - to use this one (in PBI file I call RTest so you can check)
and use this dimensions on the second visuals to show
PBI file:
DAX Problem - Add Legend to cluster Chart (counts) v2.pbix (71.5 KB)
Hope that is what are you looking for.
Best regards,
Maja
Thanks Maja, that was brilliant – though it is not entirely clear how my original solution attempt was causing a context issue in the first place. I will continue studying your solution.
Secondarily, I’m having a different issue pertaining to the same mock-up dataset. The topic title is “Reverse Cumulative Count: blank Bars when cross-filtering”, located a bit below in this topic section. Can you have a look at it? I would be very grateful. Best regards, mdalton.
For further investigation about that topic you can check Sam’s Mastering DAX calculation
(lesson: Working with one table versus many tables):
