Add comma separator in KPI visual
Hi I have the following KPI visual in a card and the formula below shows changes to prior year, see image #1. I want to have the thousands separated by a comma. So it should show (79,326).
Image #1
Can someone help?
I have attached a working file if you need it.
Thank you
WIP - Template.pbit (691.8 KB)
Hello @ysherriff,
Well, the file which you’ve provided asks for the credentials so couldn’t open it. Below is the screenshot provided for reference -
But you can try the below provided measure and I guess that should work -
PY KPI =
VAR _Difference =
[YTD] - [PY]
VAR _Direction =
SWITCH( TRUE() ,
	_Difference > 0 , "↑" ,
	_Difference < 0 , "↓" ,
VAR _Percentage =
DIVIDE( _Difference , [PY] , 0 )
VAR _Results =
_Direction & " " & FORMAT( _Percentage , "##.##%" ) & " (" & FORMAT( [PY] , "#,##0" ) & ")"
Thanks and Warm Regards,
Harsh
Perfect Harsh!!! :smiley:
Thanks a million
Hello @ysherriff,
You’re Welcome!!!
By the way, you might now have to format that thanks into the millions format. :joy:
Have a nice weekend!
Harsh
