Add a measure in Analyze in Excel?
I am using Analyze in Excel to connect to a data model on PowerBI.com.
Is it possible to add a measure in the local Analyze in Excel?
@BillK Nope, at the moment you can only create queries local to DAX Studio but you can’t use them in Analyze in Excel, because a connection string is basically a connection to your Power BI model, you drag fields in the pivot table and they are executed in Power BI service.
Thanks for the info.
