Add a character at suffix
I want to add continuous series of alphabet as suffix starting from A to ZZ in my index column which start from 1.
Example
Index New Column
1 1A
2 2B
3 3C
26 26Z
27 27AA
28 28AB
and so on.
I get upto Z using
= Table.AddColumn(#"Changed Type", "New Column", each Character.FromNumber([Index] + 64), type text)
@abinash
See if this is what you had in mind. It will work from A to ZZ, but after that I dont believe it would work. But should at least provide some sort of methodology.
Suffice continous alphabetic.pbix (12.5 KB)
Thank for your response. It looks great and resolve my problem.
Thank you :smiley:
