Hi. We have a potential client which uses the Abtrac application. Its a project management software and they’d like to create reports and dashboards in Power BI using the data from Abtrac.
Does anyone here have experience with integrating Abtrac with Power BI?
Hi @baymaxx,
As I have been able to read on the Abtrac software website, ( Answers to all your questions | Abtrac, it is a cloud application and uses the Microsoft SQL Server Azure database.
To obtain the data, it indicates that it is possible to export the csv format, but I have made a query to see if it is possible to obtain the data through queries to the database or using an API. Let’s see what they respond.
Regards
Hi @baymaxx, did the response provided by @jafernandezpuga help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @baymaxx, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
