yeah post the full M script please
= Table.AddColumn(#“Changed Type1”, “Custom”, each Table.AddColumn(“Purchase Duration”, each let
pTerminal = [Terminal ID],
pDayName = [Purchase Start Day Name],
pStartDate = Date.From([#“Purchase Start Date & Time”]),
pStartTime = Number.From(Time.From([#“Purchase Start Date & Time”])),
pAmount = Number.From( [Purchase Amount]),
rTable = Table.SelectRows( BufferTariffs, (BT)=>
BT[Terminal ID] = pTerminal and
BT[Day Name] = pDayName and
BT[Tariff Start Date] <= pStartDate and
BT[Tariff End Date] >= pStartDate and
BT[Tariff Amount Start] <= pAmount and
BT[Tariff Amount End] >= pAmount and
( Number.From(BT[Tariff Start Time 1]) * ( 1 / 24 ) <= pStartTime and
Number.From(BT[Tariff End Time 1]) * ( 1 / 24 ) > pStartTime ) or
( Number.From(BT[Tariff Start Time 2]) * ( 1 / 24 ) <= pStartTime and
Number.From(BT[Tariff End Time 2]) * ( 1 / 24 ) > pStartTime )
in if Table.RowCount(rTable) >0 then Text.Combine( List.Transform(rTable[Tariff Duration], each Text.From(_)), ", ") else null, type text))
Need the full M script of your Purchases query - thanks
How do I get that? It was queried in steps.
Sorry…realised in advanced editor.
let
Source = Table.Combine({Flowbird, IPS, MiPermit}),
#“Replaced Value” = Table.ReplaceValue(Source,null,“MiPermit”,Replacer.ReplaceValue,{“Payment Type”}),
#“Inserted Time” = Table.AddColumn(#“Replaced Value”, “Time”, each DateTime.Time([#“Purchase Start Date & Time”]), type time),
#“Inserted Day Name” = Table.AddColumn(#“Inserted Time”, “Day Name”, each Date.DayOfWeekName([#“Purchase Start Date & Time”]), type text),
#“Reordered Columns” = Table.ReorderColumns(#“Inserted Day Name”,{“Terminal ID”, “Purchase Start Date & Time”, “Time”, “Day Name”, “Purchase Amount”, “Payment Type”, “Purchase End Date & Time”}),
#“Renamed Columns” = Table.RenameColumns(#“Reordered Columns”,{{“Time”, “Purchase Start Time”}, {“Day Name”, “Purchase Start Day Name”}}),
#“Inserted Date” = Table.AddColumn(#“Renamed Columns”, “Date”, each DateTime.Date([#“Purchase Start Date & Time”]), type date),
#“Renamed Columns1” = Table.RenameColumns(#“Inserted Date”,{{“Date”, “Purchase Start Date”}}),
#“Reordered Columns1” = Table.ReorderColumns(#“Renamed Columns1”,{“Terminal ID”, “Purchase Start Date & Time”, “Purchase Start Date”, “Purchase Start Time”, “Purchase Start Day Name”, “Purchase Amount”, “Payment Type”, “Purchase End Date & Time”}),
#“Duplicated Column” = Table.DuplicateColumn(#“Reordered Columns1”, “Purchase End Date & Time”, “Purchase End Date & Time - Copy”),
#“Split Column by Delimiter” = Table.SplitColumn(Table.TransformColumnTypes(#“Duplicated Column”, {{“Purchase End Date & Time - Copy”, type text}}, “en-GB”), “Purchase End Date & Time - Copy”, Splitter.SplitTextByDelimiter(" ", QuoteStyle.None), {“Purchase End Date & Time - Copy.1”, “Purchase End Date & Time - Copy.2”}),
#“Changed Type” = Table.TransformColumnTypes(#“Split Column by Delimiter”,{{“Purchase End Date & Time - Copy.1”, type text}, {“Purchase End Date & Time - Copy.2”, type text}}),
#“Renamed Columns2” = Table.RenameColumns(#“Changed Type”,{{“Purchase End Date & Time - Copy.1”, “Purchase End Date”}, {“Purchase End Date & Time - Copy.2”, “Purchase End Time”}}),
#“Changed Type1” = Table.TransformColumnTypes(#“Renamed Columns2”,{{“Purchase End Date”, type date}, {“Purchase End Time”, type time}}),
BufferTariffs = Table.Buffer(Tariffs ),
#“Added Custom” = Table.AddColumn(“Changed Type1”, “Custom”, each Table.AddColumn(“Purchase Duration”, each let
in
#“Added Custom”
Give this a go.
let
#"Replaced Value" = Table.ReplaceValue(Source,null,"MiPermit",Replacer.ReplaceValue,{"Payment Type"}),
#"Inserted Time" = Table.AddColumn(#"Replaced Value", "Time", each DateTime.Time([#"Purchase Start Date & Time"]), type time),
#"Inserted Day Name" = Table.AddColumn(#"Inserted Time", "Day Name", each Date.DayOfWeekName([#"Purchase Start Date & Time"]), type text),
#"Reordered Columns" = Table.ReorderColumns(#"Inserted Day Name",{"Terminal ID", "Purchase Start Date & Time", "Time", "Day Name", "Purchase Amount", "Payment Type", "Purchase End Date & Time"}),
#"Renamed Columns" = Table.RenameColumns(#"Reordered Columns",{{"Time", "Purchase Start Time"}, {"Day Name", "Purchase Start Day Name"}}),
#"Inserted Date" = Table.AddColumn(#"Renamed Columns", "Date", each DateTime.Date([#"Purchase Start Date & Time"]), type date),
#"Renamed Columns1" = Table.RenameColumns(#"Inserted Date",{{"Date", "Purchase Start Date"}}),
#"Reordered Columns1" = Table.ReorderColumns(#"Renamed Columns1",{"Terminal ID", "Purchase Start Date & Time", "Purchase Start Date", "Purchase Start Time", "Purchase Start Day Name", "Purchase Amount", "Payment Type", "Purchase End Date & Time"}),
#"Duplicated Column" = Table.DuplicateColumn(#"Reordered Columns1", "Purchase End Date & Time", "Purchase End Date & Time - Copy"),
#"Split Column by Delimiter" = Table.SplitColumn(Table.TransformColumnTypes(#"Duplicated Column", {{"Purchase End Date & Time - Copy", type text}}, "en-GB"), "Purchase End Date & Time - Copy", Splitter.SplitTextByDelimiter(" ", QuoteStyle.None), {"Purchase End Date & Time - Copy.1", "Purchase End Date & Time - Copy.2"}),
#"Changed Type" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Purchase End Date & Time - Copy.1", type text}, {"Purchase End Date & Time - Copy.2", type text}}),
#"Renamed Columns2" = Table.RenameColumns(#"Changed Type",{{"Purchase End Date & Time - Copy.1", "Purchase End Date"}, {"Purchase End Date & Time - Copy.2", "Purchase End Time"}}),
#"Changed Type1" = Table.TransformColumnTypes(#"Renamed Columns2",{{"Purchase End Date", type date}, {"Purchase End Time", type time}}),
#"Added Custom" = Table.AddColumn( "Changed Type1", "Purchase Duration", each let
pStartDate = Date.From([#"Purchase Start Date & Time"]),
pStartTime = Number.From(Time.From([#"Purchase Start Date & Time"])),
(( Number.From(BT[Tariff Start Time 1]) * ( 1 / 24 ) <= pStartTime and
Number.From(BT[Tariff End Time 2]) * ( 1 / 24 ) > pStartTime ))
in if Table.RowCount(rTable) >0 then Text.Combine( List.Transform( rTable[Tariff Duration], each Text.From(_)), ", ") else null, type text)
in
#"Added Custom"
As a step for a customised column? Or new query?
Forgot to remove the last bracket, I apologise, please try again
Select everything in the Advanced Editor and replace it with this.
let
in
#"Added Custom"
It’s missing the # in front of the name…
so where it says
#“Added Custom” = Table.AddColumn( “Changed Type1”,
change that into
#“Added Custom” = Table.AddColumn( #“Changed Type1”,
Past this into the formula section, you’ve depicted.
let
Don’t forget to check the formula bar afterwards and if this step references BufferTarrifs as first argument in Table.AddColumns you need to change that into the step before that #“Changed Type1”
Yes and double click the column header for your [Terminal ID] column
and remove the non printable char at the end of the name
Is that as Insert Step? I am not a computer scientist. Merely a PhD Maths Student who has never had to use code, unless at undergraduate.
Make sure you have the last step selected in that Query before you change the name
A new Rename Column step will be added
