A table of multiple values was supplied where a single value was expected
Right, for a returned multiple value check all your filter conditions against the dimension table to identify the issue.
Best of luck.
I have uploaded an excel file with some sample data that highlights the the problem of returning multiple values, even after following your advice and using the DAX that you provided to create a calculated column.
Any help will be gratefully received. Sample File Duration.xlsx (40.9 KB)
Hi @chrisgreenslade,
Some records don’t meet all of the criteria and return a blank, I don’t have multiple results in the provided sample set. You chose the least favarable option on offer, the calculated column so I included a PQ Custom Column again as well.
Here’s the sample. eDNA - Lookup with CONTATENATEX v2.pbix (136.9 KB)
Best of luck
Hi @Melissa.
Ideally I wanted to have a measure, but when I tried this using your DAX, it didn’t work. Similarly for the PQ option. Which is why I ended up going for the calculated column.
I will see if I can get to the bottom of this.
I get the error
Expression.Error: The name ‘BufferedTariffs’ wasn’t recognized. Make sure it’s spelled correctly.
That variable, is a manual step I created and references the output of the Tariff query.
Take a look at the first step in your Puchase query…
Sorry, I really don’t understand.
If you’ve only copied the logic from the custom column (3) you’re missing a piece…
You also need to add this step (2) to your query.
Thank you for being so patient with me. So does the BufferedTariff go before the Source step?
Don’t mean to confuse you any further but it doesn’t really matter where you put it.
I’ve placed it in the Purchase query before the Source step because it calls a different table and when you use the UI to built your queries PQ will automatically reference the previous step for you and you don’t need to transform this BufferedTariff only access it for the custom column logic…
I hope this is helpful
OK
So I did apply that step in PQ within my Purchases table. However, I still got the same error as above when I then used a customised column with the code you gave.
So I am not sure what is happening.
Please show the error message
It was this one.
Post a picture showing the Applied steps pane for that query, thanks
Thanks.
Your step isn’t called BufferedTariffs but Buffer(Tariffs) so either change that step name or amend the code and call #“Buffer(Tariffs)” instead ALSO in the last step you are transforming #“Buffer(Tariffs)” you’ll need to change that into #“Changed Type1”
So I now have this. My last step was a customised column with your code in.
And I get error in each row of the Duration column created.
Okay mayby I wasn’t clear enough
in the last step you are transforming BufferedTariffs you’ll need to change that into #“Changed Type1”, so the step before that…
This refers to the part “I’ve placed it in the Purchase query before the Source step because it calls a different table and when you use the UI to built your queries PQ will automatically reference the previous step for you and you don’t need to transform this BufferedTariff only access it for the custom column logic…”
Still nothing.
When you click off to the side in the white space of the error it might refer to your [Terminal ID] column, if it does go to your Tariffs query and see if there is a non-printable character at the end of that Column name - if so remove that, please.
