I’m struggling to calculate a 5yr Moving average. or even fixed average like it is used in the visual (similar to line and stacked column) attached.
It feels like an easy solution am missing somehow.
if you want to create time intelligence measures you first need a relationship between your Calendar Table and Fire Audits.
Before concentrating on the final result, you need to understand very well your data. From what I saw, you are trying to calculate the value of a state for a selected year and the value fro the year prior.
in your data, you only have the information for the state for a one year only.
In order to check your data, my recommendation is to always start with putting the data into tables.
Moving AVERAGE 5 Y =
AVERAGEX(
DATESINPERIOD( 'Date Table'[Date] ,
LASTDATE( 'Date Table'[Date] ),
-5,
YEAR
[Total Audits])
I duplicated your first page to test the numbers.
I focused only on AVON:
First I checked the Total Audits LY, then my moving average formula. Looks fine
I went back to the main page and changed the chart to Line and Clustered column chart
I added the moving average on Line values
I went to format and made the modifications below
