Upon clicking on the link inside the " Starting Out Learning Power BI from Scratch in 2024" guide on the https://app.enterprisedna.co/app/resources page, I get a 404 error.
Thank you - I used the path you suggested and downloaded the file with no issues. I do believe the link referenced from the deck I mentioned in my original reporting of this [404] error should also be fixed, but for now, thanks to you I have the workaround to get what I need.
Hi @mtyler306
I didn’t get the error when i did it from process that I layed out above for the Starting Out Learning Power BI from Scratch in 2024 ".
Course for Chaggpt for power bi users seems to working fine. how did you get the error on that course?
If you can give more information on how what you were doing then EnterpriseDna team can look at it.
