I thought there was a video about creating 3YR Averages but I cannot seem to find it.
Hi @jmwdba
Could you please explain more what do you need?
Do you mean that you need to create 3 Years Average of sth, revenue for example?
Correct the revenue by month for the last 3 years by calendar year, I need to take the average by month.
Hi @jmwdba,
I think about a formula but without data itās difficult to answer to you.
Have you tried something like that : AVERAGEX( VALUES( [Month & Year] ), [Total Revenue] ) ?
This kind of formula gives you the average monthly revenue.
Best regard,
Joaly
What I used for now is the following formula. The thing with Power BI is never knowing what the best approach is and if there is a better way to do something.
Registrations rolling average =
IF(
ISFILTERED('Dates'[Date]),
ERROR("Time intelligence quick measures can only be grouped or filtered by the Power BI-provided date hierarchy or primary date column."),
VAR __LAST_DATE = ENDOFYEAR('Dates'[Date].[Date])
VAR __DATE_PERIOD =
DATESBETWEEN(
'Dates'[Date].[Date],
STARTOFYEAR(DATEADD(__LAST_DATE, -3, YEAR)),
__LAST_DATE
AVERAGEX(
CALCULATETABLE(SUMMARIZE(VALUES('Dates'), 'Dates'[Date].[Year]), __DATE_PERIOD),
[Registrations],
ALL(
'Dates'[Date].[QuarterNo],
'Dates'[Date].[Quarter],
'Dates'[Date].[MonthNo],
'Dates'[Date].[Month],
'Dates'[Date].[Day]
Is your formula working ?
If you want a rolling average, maybe you need to put Date instead of _LAST_DATE in the DATESBETWEEN ?
Iām not sure, without example itās more difficult to answer to youā¦
Best regards,
Joaly
Hi @jmwdba, did the response provided by the other users and exerts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
I hope that you are having a great experience using the Support Forum so far. Kindly take time to answer the Enterprise DNA Forum User Experience Survey, we hope youāll give your insights on how we can further improve the Support forum. Thanks!
Hi @jmwdba, weāve noticed that no response has been received from you since August 27. We just want to check if you still need further help with this post? In case there wonāt be any activity on it in the next few days, weāll be tagging this post as Solved.
Hi @jmwdba, due to inactivity, a response on this post has been tagged as āSolutionā.
The measure provided above that is being used (also included below for reference) technically "works " for a portion of the year. Our organizationās fiscal year starts July 1 and ends June 30. What happens when weāre looking at the 3 year averages with our formula is that the values for July through December for FY19 are missing in the data set, which is causing incorrect averages for those months.
We would like to reflect our fiscal year start and end to be āJuly 1ā and āJune 30ā instead of the standard āJan 1ā to āDec 31ā stard/end. Is this possible to do within the formula below? Or would there be a different measure that would need to be used to accommodate our fiscal year?
IF(
ISFILTERED(āDatesā[Date]),
ERROR(āTime intelligence quick measures can only be grouped or filtered by the Power BI-provided date hierarchy or primary date column.ā),
VAR __LAST_DATE = ENDOFYEAR(āDatesā[Date].[Date])
VAR __DATE_PERIOD =
DATESBETWEEN(
āDatesā[Date].[Date],
__LAST_DATE
AVERAGEX(
CALCULATETABLE(SUMMARIZE(VALUES(āDatesā), āDatesā[Date].[Year]), __DATE_PERIOD),
[Registrations],
ALL(
āDatesā[Date].[QuarterNo],
āDatesā[Date].[Quarter],
āDatesā[Date].[MonthNo],
āDatesā[Date].[Month],
āDatesā[Date].[Day]
Hi @jmwdba,
You are leveraging the auto date/time āfeatureā in Power BI.
My advise would be to disable that (globally) always incorporate a proper date table in your model - if that includes a date column anywhere. Donāt forget to mark that, as a Date Table. Once thatās in place you can include FY columns in your calculations.
Two Examples from the M showcase category:
I hope this is helpful
Hi @Melissa ,
Thanks for your response.
From your message, I disabled the āauto date/timeā in the current report, as this is for a special report and auto data/time is not an issue in our other reports.
Also, I marked our āDatesā table as a āData Tableā. This caused a couple of our rolling measures to break that were using some of the hierarchy components (i.e. āDatesā[Date].[Year], āDatesā[Date].[Month], etc). I set the āDateā as the āDate Columnā for the date table. However, when I try creating a new date hierarchy to be within the āDateā field, it creates the hierarchy as a separate fieldā¦and I am unable to use the components of the hierarchy in the measure to fix them.
Iām trying to understand what I may be missing after Iāve disabled auto date/time and marked our āDatesā table as a data table in order to get the hierarchy.
Regarding your comment, āOnce thatās in place you can include FY columns in your calculationsā, does that imply that date hierarchies wouldnāt be needed in the measures, but instead FY columns (i.e. FY Quarter, FY MonthNo, etc.) would replace them?
Thank you.
maybe providing your power bi file will help and using the date table that Mellisa M code will help too
Precisely, those columns are attributes of a Date and their purpose is to filter, slice and dice your data by. Found an older post that might be of interest to you, just amend it to fit your scenario.
Hi @Keith,
Unfortunately due to confidential organizational data, I am unable to share the data file. This would require approval from Info Security Team. Also, it would take some time to set up a report with dummy data to reflect the actual scenario.
Thanks.
Thanks for the information. Iāll see if Iām able to get the end result weāre looking for. I appreciate the help.
Generally - a sample of dummy data is good enough for forum members to work with. We donāt need to see your actual data (most of us are dealing with sensitive data, so we do understand that
What is needed is something that represents your problem - so an example of the relative tables and measures.
The post below provides some excellent information on building out a dummy dataset for use in requesting help from the forum.
https://forum.enterprisedna.co/t/tip-tools-and-techniques-for-providing-pbix-files-with-your-forum-questions/17763
HI @jmwdba
Yes i understand that fully but the EDNA Team has put together a process that you can mask the data.
please see the below link
https://forum.enterprisedna.co/t/how-to-mask-sensitive-data-in-power-bi/7788
this will help us all
thanks
Keith
Hi @jmwdba,
Made some changes to your measure, hopefully you can translate this to your production file and it gets you the expected result. Nothing more I can do, really, without a sample fileā¦
Note. Your dates table needs to include full Fiscal Years.
IF(
ISFILTERED( 'Dates'[Date] ),
ERROR( "Time intelligence quick measures can only be grouped or filtered by the Power BI-provided date hierarchy or primary date column." ),
VAR __LAST_DATE =
CALCULATE( MAX( 'Dates'[Date] ), DATESYTD( 'Dates'[Date], "30-6" ) )
VAR __FIRST_DATE =
CALCULATE( MIN( 'Dates'[Date] ), DATESYTD( 'Dates'[Date], "30-6" ) ),
DATEADD( 'Dates'[Date], -3, YEAR )
VAR __DATE_PERIOD =
DATESBETWEEN( 'Dates'[Date], __FIRST_DATE, __LAST_DATE )
AVERAGEX(
CALCULATETABLE(
SUMMARIZE( 'Dates', 'Dates'[Fiscal Year] ),
__DATE_PERIOD
CALCULATE( [Registrations], ALLEXCEPT( 'Dates', 'Dates'[Fiscal Year] ) )
Hello @jmwdba, good to see that you are having progress with your inquiry. Did the response from the users and experts help you solve your inquiry?
If not, like @Keith mentioned above, kindly send us your masked PBIX file.
Here are some videos that may help you masking sensitive data and create datasets and data models representative of your problem:
