3 Month Trend Reporting by Projects
Hi All,
I need to generate a very simple table but for some reason, I can’t seem to get my head around this. Basically, I have a table that includes RAG status by project over period (months). See image below:
Then, I need to calculate a change in status between months (using the RAG Score) for each project and show a trend status over the past 3 months. See image below:
Basically, if the RAG score difference between months
  • is >0 then green up arrow
  • is = 0 then amber dash
  • is <0 then red down arrow.
I have attached the pbix and the input data files where I have started to construct this and the main problems I am having are:
  1. setting the Month -1, Month -2, Month -3 variables
  2. filtering the score using the above variables.
I hope you can understand the context and the issues I am having. Any direction and help will be appreciated.
Thank you in advance.
Trend Status Example.pbix (41.0 KB)
Trend Status Example.xlsx (13.4 KB)
@tt.xavier
Create measures like below
Trend Status Example.pbix (42.7 KB)
Rajesh,
Thank you so much for the solution. Have a great day.
Cheers
