Hello @ysherriff,
Firstly, in order to achieve the results based on the “Image 1” which you’ve provided in your initial post can be achieved as per the steps suggested below -
1). In your Date hierarchy, add the field “Month” inside it.
2). Create a visual based on the hierarchy - “Year > Month”.
3). Drill-down from Year level to Month level in the chart.
4). Turn on the “Concatenate labels” inside the X-axis option.
Now, you’ll get the expected results as per the “Image 1”. Below is the screenshot of the final results provided for the reference -
Finally, the answer to your query -
“I do not see the X-Axis Type Categorical. Do you know how I can activate it? For the life of me, I tried everything but can’t seem to find how to activate it.”
Answer: The option of - “Continuous V/s Categorical” is available or visible inside the formatting pane only, in the case, when you’re present at a numerical level onto the X-Axis. Below is the screenshot provided -
So as you can see in the above screenshot, when your X-Axis is in the form of Number or Numericals, Power BI gives you the option of converting it into either “Continuous or Categorical” type. But when you drill-down further into the next level i.e., at a Month level. The X-Axis is now in the form of Text level since Month is in a Text format. And therefore, at this level, the option of “Continuous or Categorical” is no more available. The reason being is, text format cannot be of a continuous data type and hence, they’re by default converted into the “Categorical Type” Below is the screenshot provided -
When you’ll drill-up then again you’ll start to see those options again.
Thanks and Warm Regards,
Harsh
WIP File - Harsh.pbix (56.6 MB)
