Visual Suggestion
Hello all,
Please what type of viual can i use to simulate the attached business requirement. I need to compare data from two different sources. Please see attached. Thank you.
Hi Yeti,
Is the business requirement to find or to visualize differences between the data in the two sources?
There are many ways to get this accomplished through Power BI. I would start with a Matrix or Table and see if that works for you. If you run into issues after that, post a sample PBIX file so we can better assist. Most times a sample file is better than a picture when asking questions here in the forum.
