I have created a measure that calculates an average actual unit cost year to date for a product. What I want to be able to do is to then use that actual ytd as a constant to put into a measure formula to calculate total anticipated future monthly costs (anticipated monthly volumes x average unit cost ytd). And then as each month rolls through and we get more actuals and the average ytd cost changes accordingly.
Is that possible?
Hi @Howard_Davies, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi
Have you had a look at this training relating to forecasting?
@Howard_Davies, I think using screen shot of the measure you created earlier and the data view will help us to understand your questions better.
Thanks for posting your question @Howard_Davies. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Hi @Howard_Davies, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
