Updated Mastering DAX Calculations Course Now Officially Launched
Have you seen the updated Mastering DAX Calculations Course? In case you haven’t seen it yet, check it out and learn some DAX calculations tips and tricks.
If you have any questions regarding this post, feel free to re-open the thread by removing the removing the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. You may check this how-to guide for reference - How To Use The Enterprise DNA Support Forum Thanks!
Is there supposed to be a .pbix file in the course resource pack download.zip file?
Logical Functions - IF/SWITCH
I’m having some difficulty matching the visual to what appears in the course. I must be missing something. Where is my mistake?
I figured out that I needed to add IF( ISBLANK( [Sales LY] ),
BLANK(), to the YoY Sales Difference formula!
Little late response but I believe it’s there…
