Unpivot question
I have a table that has userid and project id going down, and month going across, with 3 values per month.
Picture something like this:
userid	project id	jan actl hrs	jan fcst hrs	jan pct	feb actl hrs	feb fcst hrs	feb pct
aa123a	proj1	12	5	20%	41	30	30%
aa123a	proj2	14	7	18%	45	40	35%
bb123a	proj1	5	1	1%	17	25	19%
bb123a	proj3	55	50	28%	33	27	17%
I could unpivot the whole lot, but my problem is that I want the hours formatted as integers, and the percentages formatted as percentages.
I don’t know how to make that happen with simple attribute/value pairs resulting from unpivot.
Alternatively, I thought about making the data look like this:
userid	project id	month	actl hrs	fcst hrs	pct
aa123a	proj1	jan	12	5	20.00%
aa123a	proj1	feb	22	30	30.00%
aa123a	proj2	jan	14	7	18.00%
aa123a	proj2	feb	33	40	35.00%
bb123a	proj1	jan	5	1	1.00%
bb123a	proj1	feb	11	25	19.00%
bb123a	proj3	jan	55	50	28.00%
bb123a	proj3	feb	33	27	17.00%
But I don’t know how to make that happen using unpivot either.
Any suggestions?
@brixmitch
Dont see why this cant be done. Any chance you upload a sample of what the data is and then something that shows what you would want the data to be? It’s hard to see exactly in the data above.
Thanks-
Nick
pivot & unpivot data.xlsx (11.3 KB)
didn’t know i could actually upload files. here ya go!
@brixmitch
I think this should do it. Here’s the final output
There’s a parameter for the file location, be sure to change that. Also, not sure what the “% pct” column is, but generally those types of calculations are better in DAX vs. in Power Query/Calculated column
EDNA Unpivot.pbix (12.8 KB)
What a fascinating set of data manipulations! merge, transpose, uinpivot, split, merge, pivot…
I can honestly say I would never have thought of that on my own.
Thanks!!!
After a while you see the same basic patterns, just a different wrinkle here and there. And please don’t think for one second I did that all in one try. Took a few “lets see what this does” type of things.
Thanks to the contributors of this post. Due to the length by which this post has been active, we are tagging it as Solved. For further questions related to this post, please make a new thread.
