I’m not sure how you want to visualize this, but I think one effective way is to use a matrix visual with some conditional formatting to color in the blank areas:
I’m happy to help you here, but at this point to productively move forward what I need is a mockup of the outcome you are trying to achieve. That can be in the form of Excel, PowerPoint or even a hand-drawn sketch. Just something to give me an idea of what you want the report/visual to look like.
Hi @Nagi_k, we’ve noticed that no response has been received from you since the 7th of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
