Here is the sample PBIX file:
- Value_type.pbix (33.5 KB)
I stumbled across the #shared object yesterday. I want to categorise the shared objects by type i.e table, function, number etc. The only way I found to do this was an ugly long conditional custom column. Here is my transform:
let
Source = #shared,
to_table = Record.ToTable(Source),
sort_asc = Table.Sort(to_table,{{"Name", Order.Ascending}}),
// try checking Function or else
check_type = Table.AddColumn(
sort_asc, "type_text",
// Values are not recognised as types
each if Value.Is([Value], type function) then "function"
else if Value.Is([Value], type table) then "table"
else if Value.Is([Value], type list) then "list"
else if Value.Is([Value], type record) then "record"
else if Value.Is([Value], type number) then "number"
else if Value.Is([Value], type text) then "text"
else if Value.Is([Value], type time) then "time"
// Types are not recognised as Values
else if Type.Is([Value], type binary) then "binary"
else if Type.Is([Value], type table) then "table"
else if Type.Is([Value], type list) then "list"
else if Type.Is([Value], type record) then "record"
else if Type.Is([Value], type number) then "number"
else if Type.Is([Value], type text) then "text"
else if Type.Is([Value], type time) then "time"
else if Type.Is([Value], type datetime) then "datetime"
else if Type.Is([Value], type datetimezone) then "datetimezone"
else if Type.Is([Value], type date) then "date"
else if Type.Is([Value], type duration) then "duration"
else if Type.Is([Value], type logical) then "logical"
else if Type.Is([Value], type type) then "type"
else if Type.Is([Value], type null) then "null"
else if Type.Is([Value], type none) then "none"
else if Type.Is([Value], type any) then "any" // condition true for everything so put last
else "other") // should be no other types: all should be categorised
in
check_type
Question 1
Is there a cleaner way to inspect types and categorise the #shared object rows by type? I couldn’t sort by [Values] column without creating a new column.
Question 2
Why is function a Value and not a Type? When I tried to inspect it using Type, the error was something like: “Cannot convert Function to Type”.
