Hi, can anyone point me in the right direction on sorting columns based on another column, I have created the below basic P&L template but when i try to sort Level 1 based on the Level 1 Order column PBI says i can’t and i get the error below but i can’t for the life of me figure out the issue, thanks in advance.
The blanks, I’d guess. Try removing them, then try again.
Hi, that worked thanks but i wanted to keep the blanks as that forms pasr of the layout, how can i keep the blanks and still sort?
Perhaps give each blank its own sort number, a decimal (e.g., 3.1) to make it appear in the desired place.
@BCS,
If you want to go full galaxy-brain approach on this, you can replace each blank with a unique number of non-printing characters, so that each field is unique but to the naked eye they all just look like blanks. Probably overkill, but sure to impress your Power BI friends.
Here’s the article that lays out how to do it:
- Brian
Thanks very much for the help folks!
