Hi All,
i have a requirement where i need to schedule the report output to excel/csv format? i know r script we can automate the visual to csv but any other ways (not dax studio as that’s manual and report builder is expensive).
thanks in advance.
Hi All,
thanks in advance.
Hi @Ravi85, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Include the masked PBIX file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details
Hi @Ravi85, we’ve noticed that no response has been received from you since the 26th of January. We are waiting for the masked PBIX file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details
This will help other users and experts to answer your inquiry better. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
