Tracey
March 14, 2023, 12:19pm
#1
Hello Power BI Experts
I would have thought this DAX would be easy to solve, but I’m stumped!!
I’m creating a table (1-100)
Adding a calc column
Filtering the table, then
finding the min value
Min Spares =
var __pnso = 0.95
var __ExpectedFailures = 0.3280
var __sparesValue = GENERATESERIES(1, 100, 1)
var __caltable =
SELECTCOLUMNS (
__sparesValue,
“Min Spares”, [Value],
“Calc”, [Value] * __ExpectedFailures)
var __filteredSpares =
FILTER(__calctable, [Calc] >= __pnso)
var __calculation =
MIN(__filteredSpares[Min Spares])
return __calculation
*** You should be able to cut and paste this code, to return the __calucation value.
I get an error, "Table variable '__filteredSpares cannot be used in current context becase a base table is expected.
Please could you HELP!!!
Thanks,
Tracey
@Tracey Use MINX/MAXX/SUMX. SUM, MIN, MAX etc don’t work with variables.
Hello @Tracey ,
Did the responses above from @AntrikshSharma help solve your query?
Thank you
Hello @Tracey
We’ve noticed that no response was received from you on the post above.
Just following up if the response above help you solve your inquiry.
If it did, please mark his answer as the SOLUTION.
Hi @Tracey
Due to inactivity, a response on this post has been tagged as “Solution”.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey, .
We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
emphasized text
