SWITCH Optimization
Hi, it is a simple code with SWITCH statement, but I had to add extra groups and then everything slowed down. How could I optimize this?
test_New Price =
VAR vPurchase_price_EUR = CALCULATE(SUM(Invent[EstCostPrice])*[Currency ratio Value])
SWITCH(TRUE(),
– pricing
SELECTEDVALUE(Invent[GroupId]) = "101",
DIVIDE(vPurchase_price_EUR,(1-0.80)),
SELECTEDVALUE(Invent[GroupId]) = "102",
DIVIDE(vPurchase_price_EUR,(1-0.70)),
SELECTEDVALUE(Invent[GroupId]) = "103",
DIVIDE(vPurchase_price_EUR,(1-0.55)),
SELECTEDVALUE(Invent[GroupId]) = "104",
DIVIDE(vPurchase_price_EUR,(1-0.90)),
SELECTEDVALUE(Invent[GroupId])= "105",
DIVIDE(vPurchase_price_EUR,(1-0.35)),
SELECTEDVALUE(Invent[GroupId]) = "190",
DIVIDE(vPurchase_price_EUR,(1-0.25)),
SELECTEDVALUE(Invent[GroupId])= "195",
DIVIDE(vPurchase_price_EUR,(1-0.60)),
SELECTEDVALUE(Invent[GroupId]) = "198",
–SONY
SELECTEDVALUE(Invent[GroupId]) = “211” && SELECTEDVALUE(Invent[Brand])=“Sony”,
SELECTEDVALUE(Invent[GroupId]) = “211” ,
DIVIDE(vPurchase_price_EUR,(1-0.30)),
–ELSE // All other
DIVIDE(vPurchase_price_EUR,(1-0.50)))
Hi @Vladas,
Its very difficult to optimize a dax measure by just looking at it. you have to provide more context to the calculation as why are you writing such a long expression and what is the end goal you want to achieve. Further for optimization purpose a mock up of your existing model is important and also if you can share the vpax file of your model probably then we can think of helping you in terms of optimization.
Regards,
Hemant
Hi @Vladas, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Vladas, we’ve noticed that no response has been received from you since the 18th of November. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
