I’m trying to replicate the excel vlookup function in Power BI, and I have a question about how to return values based on a specific filter order.
I’m trying to fetch surgery ID’s from a surgery table and map them onto the touchpoints table. The relationship is many-to-one. That is, there is only 1 Lead ID on the touchpoints table, however each Lead could show up in multiple records on the surgery table. I understand that firstnonblank fetches the first match it finds, however, I’m wondering if I can use DAX to fetch the surgery ID based on a specific sorting order for surgery status.
I would like to return the surgery ID in the following order:
surgery status = blank. If there’s no matches for a blank surgery status, then
surgery status = completed
then surgery status = cancelled
then surgery status = late cancelled
and finally, surgery status = Patient DNS.
My current DAX is fetching values as expected, but I’m not sure it’s finding matches in the correct order.
Surgery ID =
CALCULATE (FIRSTNONBLANK(FactSurgeryDetails[SurgeryID], 1 ),
FILTER ( ALL (factsurgerydetails), FactSurgeryDetails[Lead ID] = facttouchpoints[LeadID] ),
FactSurgerydetails[SurgeryStatus] = BLANK()
|| FactSurgerydetails[SurgeryStatus] = "Completed"
|| FactSurgerydetails[SurgeryStatus] = "Cancelled"
|| FactSurgerydetails[SurgeryStatus] = "Late Cancelled"
|| FactSurgerydetails[SurgeryStatus] = "Patient DNS"),
Is this the correct way to structure the dax to instruct the firstnonblank to return values in the order specified above? I was thinking that I may have to separate each of the surgery status filters using commas:
Surgery ID =
FactSurgerydetails[SurgeryStatus] = BLANK(),
FactSurgerydetails[SurgeryStatus] = "Completed",
FactSurgerydetails[SurgeryStatus] = "Cancelled",
FactSurgerydetails[SurgeryStatus] = "Late Cancelled",
@BrianJ , any ideas?
Thanks!
Pete
