Sorting a sorted column
How do I sort a sorted column? It wouldn’t work through the regular visual sorting, tried adding a sorting column, but wouldn’t do it and found a partial solution on the pie chart visual, by adding the sorting column on the Tooltips field. But that only works for the Pie chart visual, as it has the Tooltips on it, while on a regular Matrix won’t work.
I’ve attached some printscreens for details.
Trying to sort ascending the Aging column.
Sorting%20issue
Thank you.
Daniela
Hi, Daniela! There is great video with tipes how to soft the Matrix (visual that doesnt have tooltips field. https://www.youtube.com/watch?v=1bp_e-ik7aA
Thank you Ivanka.
It’s really a good solution.
Thank you.
You are welcome. Happy to help.
