I need to slice my Transactions (Sitting on my AccountTransaction Table) based on the Receivable Name (located on ReceivableAccount).
Is there any way I can create that slicer?
thanks in advance, Ezequiel
My guess here is that with the cascading relationship from ReceivableAccount to ReceivableInvoice to AccountTransaction it should work by dragging receivable name to the slicer.
If it is not working or giving misleading results then you may not be working with a true cascading relationship style data model, but I can’t see that from the screen shot
Pete
Hello @ezenunez
I hope that the responses above were able to help you with your query.
Please don’t forget if your question has been answered within the forum it is important to mark your thread as ‘solved’.
Since it’s been a while since we got a response from you, in case there won’t be any activity on it in the next few days, we’ll be marking an answer as a solution.
Hi @ezenunez, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
