Thanks @Melissa to this, it was possible to create a revenue display in semantic stores. Unfortunately, this metric with a date does not work. Request for help
Sample pbx: https://drive.google.com/open?id=1L2b9YIReTt27xSTmoBU8NCzDAO8QsGxO
Hi @Harris,
Here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
You can check the forum guidelines here How To Use The Enterprise DNA Support Forum . Not adhering to it may sometimes cause delay in getting an answer.
Bringing in additional dimensions like Dates for example can impact your calculations, so always design your model first. Keep in mind what you want to showcase, what you need to do so and how you want to visualize it in your report BEFORE you start writing DAX.
Revenue Bench Store =
VAR myStore = VALUES( Store_Benchmarking[StoreID_Bench] )
VAR Result = CALCULATE( [Revenue Measure], ALLSELECTED(Sales), Sales[StoreID] IN myStore )
Result
