Show [Unit Cost] through time
Hi all,
I’m trying to find a way to visualize item [Unit Cost] trough time. In order to do so effectively I would need to be able to show a value for every single day since the item first had a [Unit Cost] Value <> 0,00 before that time it should return a BLANK.
After that first time - on all dates the [Unit Cost] didn’t change I want to show the last known [Unit Cost] Value <>0. So if a change resulted in a Value =0 then I want to show the last known [Unit Cost] Value <>0 before that.
I’ve worked out what the previous date was where the [Unit Cost] <>0. But so far that didn’t get me anywhere… Any help will be much appriciated!
Attached the PBX-file Track Unit Cost trough time.pbix (159.5 KB)
Below an image of what I hope to achieve in Power BI
Try this.
Change the previous date formula to the below
Previous date UC<>0 =
CALCULATE( MAX( tDates[Date] ),
    FILTER(
        FILTER( ALL( tDates ), tDates[Date] <= MAX( tDates[Date] ) ),
            NOT( ISBLANK( [Total Costs] ) )
Then create this formula
Total Unit Cost =
VAR PreviousSales = [Previous date UC<>0]
CALCULATE( [Unit Cost],
    FILTER( ALL( tDates ), tDates[Date] =  PreviousSales ))
See below for results
Think this should do it.
Perfect!
Just added a condition to deal with a Value=0
FILTER(
NOT( ISBLANK( [Total Costs] ) ) && [Total Costs] <> 0
Thank you Sam
Nice thanks
I found this useful to solve the issue I was facing. I have a set of projects whose status are updated in a log table. I want to show in a matrix for each project the status related to the last update.
Using your suggestions I made it work, but since I have to use a scalar (the last updated status) I used the LASTNOTBLANK. I’m sure there is a smarter way to handle formulas like this.
Thanks!
ProjectLogGantt.pbix (36.6 KB)
