Hello,
I have the following requirement from a client and would like to have opinions on the feasability of it.
In an existing report, the client would like to add a date slicer on the page appearing as a date picker to select a single date. The slicer is using the date field of a date table.
There are several table visuals on the report ( yes I know Visualisation wise they are not there yet ) and all of them are using the date from the date table as well.
Because when working with the slicer you can only choose ââdate beforeââ or ââdate afterââ and not ââdate equal toââ , we would like to develop a parameter to use at the visual level.
The goal of the parameter would be to return in the table only the date selected by the date picker.
For instance, as in my attached example we would select october 20th, I only want this date in my table - see âtable- expected resultsâ.
I understand that there is no major benefit to leave the date field with the tables but the client want to keep it that way in case data is exported to excel(aaaahâŚ).
Thank you,
31102022.pbix (72.7 KB)
