Selected Bookmarks
Hi guys,
I’m wondering if it’s possible to create a variable which indicates a selected bookmark on my report.
I have a report that makes possible to navigate between charts and filters through bookmarks. As I’m using just one filter, I needed to disable bookmarks data relationship.
hope to hear from you.
Not to my knowledge at all on this.
Bookmarks essentially trigger actual changes in the report though, so you could create variables that work with items in your data - that themselves are determined by the bookmark.
That make sense.
I do not believe though that you can work out within a formula/measure what bookmark is selected. I would be happy to be proven wrong, but at the moment I’ve never seen or heard of this specifically.
