I have a report model that requires connections to two Data Gateways (Postgres & MS SQL) on different networks. One is on the local network the other is in Azure. Combining the datasources into a single gateway is not possible. Is there a way to make this work without having to combine the sources into a SSAS instance in Azure?
Hi @mkaess, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
