Hi @neilonbooysen, did the response provided by our community members help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
hi team, still struggling with this issue. backround on this:
- i used grouping and binning to group brands into categories
- i am trying to divide calls by this custom group now which is making the total go all wrong in matrix (category in columns)
- i replace the categories in point to with a month value and the totals are perfect.
so in summary it seems the custom group is causing the calculation to go wrong, any ideas on how to get around this? maybe another method?
Hi @neilonbooysen! We noticed that your inquiry was left unsolved for quite some time now.
