Hi I have a PQ that does a Combine and Transform. Some Files do not have the Table that the PQ queries in and so I get errors - see attached image.
To handle this I have a Remove error action in the Query.
However, it seems that if all the files have errors and are removed then I get a second error
how does one handle this ?
Thank You
Allister
> let > Source = #"Folder Parameter", > #"Filtered Hidden Files1" = Table.SelectRows(Source, each [Attributes]?[Hidden]? <> true), > #"Invoke Custom Function1" = Table.AddColumn(#"Filtered Hidden Files1", "Transform File (2)", each #"Transform File (2)"([Content])), > #"Renamed Columns1" = Table.RenameColumns(#"Invoke Custom Function1", {"Name", "Source.Name"}), > #"Removed Other Columns1" = Table.SelectColumns(#"Renamed Columns1", {"Source.Name", "Transform File (2)"}), > #"Removed Errors1" = Table.RemoveRowsWithErrors(#"Removed Other Columns1", {"Transform File (2)"}), > #"Expanded Table Column1" = Table.ExpandTableColumn(#"Removed Errors1", "Transform File (2)", Table.ColumnNames(#"Transform File (2)"(#"Sample File (13)"))), > #"Changed Type" = Table.TransformColumnTypes(#"Expanded Table Column1",{{"Source.Name", type text}, {"Column1", type number}, {"Column2", type any}, {"Column3", type text}, {"Column4", type any}, {"Column5", type any}, {"Column6", type any}, {"Column7", type any}, {"Column8", type any}, {"Column9", type any}, {"Column10", type any}, {"Column11", type any}, {"Column12", type any}, {"Column13", type any}, {"Column14", type any}, {"Column15", Int64.Type}, {"Column16", type any}, {"Column17", Int64.Type}, {"Column18", type any}, {"Column19", type text}, {"Column20", type any}, {"Column21", type any}, {"Column22", type any}, {"Column23", type any}, {"Column24", type any}, {"Column25", type text}, {"Column26", type text}, {"Column27", type number}, {"Column28", type text}, {"Column29", Int64.Type}, {"Column30", type any}, {"Column31", type any}, {"Column32", type any}, {"Column33", type any}, {"Column34", type any}, {"Column35", type any}}), > #"Removed Other Columns" = Table.SelectColumns(#"Changed Type",{"Source.Name", "Column15", "Column19"}), > #"Filtered Rows" = Table.SelectRows(#"Removed Other Columns", each ([Column15] <> null) and ([Column19] <> null)), > #"Renamed Columns" = Table.RenameColumns(#"Filtered Rows",{{"Column15", "Value"}, {"Column19", "TransType"}}) > in > #"Renamed Columns"
