I identified KPI’s for the data below(see link):
-Comparrisons of invoices paid over time
-Sum of days to pay date
-Paid on time
-Paid on time, posted on time.
-Overview of sum by TEST
-Sum of invoices paid on time.
-Top BU by sum
-Coun Distinct Net
By looking at the data, please advise of metrics are relevant and what can be improved?
I need to use drill down functions, to get to the core why the numbers are as it displays(tips please)?
https://drive.google.com/file/d/1aHULztI9Q0Ho7ffoRcBceAiElOTIZVji/view?usp=sharing
Hi @Yrstruly, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformatted text </>.
- Use the proper category that best describes your topic
- Provide as much context to a question as possible.
- Include the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @Yrstruly, we’ve noticed that no response has been received from you since the 25th of March. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
