I would like to seek your advise that the setting in Power BI to make sure the report in Power BI Mobile can refresh and update the latest data.
Thank you.
Thank you.
Hi, any comments on the above? Thanks for your reply in advance.
Hi there, in my view this is really no different to any data refreshing capabilities.
If you set it up properly via the online service then that should reflect within you mobile as well.
It’s all the same backend. Once the data is refresh (usually via the data gateway), then its updated in the cloud and any device pulling that information should see the updated data, regardless of if you are using the web, tablet or phone.
Hopefully this gives you something to work with
